blaster right side cover
Old Jan 13, 2007 | 08:02 PM
tmzg29's Avatar
Default blaster right side cover
Ok call me an dumba#* but how in the heck do you get the right side cover off. I am trying to remove the gear for the oil injector and I have removed all the bolts from the cover and I can not get the dang thing off. I can get it loose back by the kick starter shaft but the front will not budge. Am I not being force full enough. I do not want to screw up the side cover by trying to force it off. Is there a trick to getting this off or do I need to pull out the BFH and smack it.
Please help this challenged idiot.
Old Jan 13, 2007 | 08:23 PM
tmzg29's Avatar
anyone..........I am getting mad out in the garage.........ready to get the BFH out................
Old Jan 13, 2007 | 09:28 PM
JLsparky7's Avatar
Double check and make sure there isnt any covers that just snap on and cover a screw. Your prolly just not giving it enough elbow grease but dont be mad at me if you break something! [img]i/expressions/face-icon-small-smile.gif[/img]
Old Jan 13, 2007 | 11:13 PM
Boomer2's Avatar
It should come off pretty easily. You might have forgotten a bolt. If you are sure you got all the bolts off maybe try and pry it off. I wouldn't use alot of force, you may damage something. Also make sure you pull it off evenly.
Old Jan 14, 2007 | 02:56 AM
tmzg29's Avatar
Thanks guys. I got it off. I wasn't giving it enough force. Got the rebuild completed and it is running like a top. I made my own oil blockoff kit................it was easy and cheap..............cost me 6.95 for the new clutch cover gasket.
Old Jan 14, 2007 | 10:05 AM
Boomer2's Avatar
Did You remove the gear from the pump and put the pump back. Thats alot cheaper than buying a kit also. Glad things worked out for you.
Old Jan 14, 2007 | 11:35 AM
tmzg29's Avatar
yes I removed the gear and made my own block off plate from 1/4" aluminum scraps I had laying around. All I had to buy was a new gasket for the clutch cover.
1966F100
Aug 21, 2015 07:10 PM
scott1988
Aug 18, 2015 08:44 AM
315blaster
Aug 8, 2015 08:13 PM
drewy2dope
Ask the Editor
11
Jul 31, 2015 09:36 AM
Countrygirl1976
Ask the Editor
Jul 13, 2015 12:19 AM
