trying to hook up a pro designe kill switch on my 400ex need help
well im trying to hook up a pro designe kill switch to my 400ex and cant figure out what wires to hook it up to and ware it needs to be ground any help would be great .......lol last thing i need to put on it and then its finaly time to get her on the GNCC tracks so i gotta get this thing on fast...
Take off driver side tank panel to get at coil, just use a scotch-lock connector and tap into the main electrical wire at coil, black with a yellow or green stripe with the hot wire, and you can put the ground on one of the front fender support bracket bolts that go the frame or on steering stem bolts at top.
The directions tell you that one wire is longer than the other and which is ground and so forth.
Originally posted by: 1988TRX250R
Do yourself a favor and solder the connection. I have seen more than a few electrical problems caused by scotch-locks. They are not worth a crap and should be thrown in the garbage.
when proper time is alotted, a more permanant wiring should be done.
sweaver
11
Aug 18, 2015 03:47 PM
