trying to hook up a pro designe kill switch on my 400ex need help
Old Jan 16, 2007 | 10:38 PM
drag101's Avatar
Default trying to hook up a pro designe kill switch on my 400ex need help
well im trying to hook up a pro designe kill switch to my 400ex and cant figure out what wires to hook it up to and ware it needs to be ground any help would be great .......lol last thing i need to put on it and then its finaly time to get her on the GNCC tracks so i gotta get this thing on fast...
Old Jan 17, 2007 | 02:14 AM
XR650Warrior's Avatar
Take off driver side tank panel to get at coil, just use a scotch-lock connector and tap into the main electrical wire at coil, black with a yellow or green stripe with the hot wire, and you can put the ground on one of the front fender support bracket bolts that go the frame or on steering stem bolts at top.
The directions tell you that one wire is longer than the other and which is ground and so forth.
Old Jan 18, 2007 | 01:05 AM
1988TRX250R's Avatar
Do yourself a favor and solder the connection. I have seen more than a few electrical problems caused by scotch-locks. They are not worth a crap and should be thrown in the garbage.
Old Jan 20, 2007 | 02:49 AM
I agree, they are junk, and I have had my fair share of problems with them, was just giving out info for the guy that wanted to install quick and race asap,
when proper time is alotted, a more permanant wiring should be done.
jeepwheelin02
1) Engine problems..
Jul 18, 2020 06:42 PM
Ripinandtearin
Dec 11, 2017 08:06 PM
sweaver
11
Aug 18, 2015 03:47 PM
Hatrackr
Aug 11, 2015 09:03 PM
Ripinandtearin
Jul 19, 2015 08:38 PM
