Input on winter build for 04 Raptor 660
I am thinking of tearing my bike apart and having some engine work done and get the frame powder coated while replacing bearings and stuff. What brands and/or parts would you suggest for the following:
Stroker crank w/rod
Hi comp piston
gasket kit
possibly lightened flywheel?
Here is a list fo stuff I have that I haven't got around to installing yet:
Hot Cams Stage 2 with springs
Barnett Dirt Digger clutch kit
Wiesco clutch basket
And here is what I have done so far:
Full LRD exhaust
K&N Proflo
DJ Jet kit with LRD needles
If I get the a stroker kit with piston and install the came, I will halso have some head work done. If you guys have suggestions on brand or other mods please let me know. I want to keep as much reliability as possible, so if that will be compromised in a big way with any of the above, let me know that as well and I will rethink my plan. Thanks in advance.
-Brandon
p.s. I did search, but I want fresh info. Maybe something better has come out recently that I don't know about and isn't on here yet. So if you're gonna post and say nothing but "use the search button" please save both of us some time and energy. Thanks again for any help and info offered.
Stroker crank w/rod
Hi comp piston
gasket kit
Full LRD exhaust
K&N Proflo
-Brandon
I believe in these products: Stroker crank - Four Stoke Tech (fourstroketech.net), Piston - JE, Clutch Basket - Hinson, Gaskets - I always use factory gaskets with no problems yet. I like the Webcam camshaft better than the Hotcams.
