Input on winter build for 04 Raptor 660
Old Jan 18, 2007 | 07:20 PM
RaptorRookie's Avatar
Default Input on winter build for 04 Raptor 660
I am thinking of tearing my bike apart and having some engine work done and get the frame powder coated while replacing bearings and stuff. What brands and/or parts would you suggest for the following:
Stroker crank w/rod
Hi comp piston
gasket kit
possibly lightened flywheel?
Here is a list fo stuff I have that I haven't got around to installing yet:
Hot Cams Stage 2 with springs
Barnett Dirt Digger clutch kit
Wiesco clutch basket
And here is what I have done so far:
Full LRD exhaust
K&N Proflo
DJ Jet kit with LRD needles
If I get the a stroker kit with piston and install the came, I will halso have some head work done. If you guys have suggestions on brand or other mods please let me know. I want to keep as much reliability as possible, so if that will be compromised in a big way with any of the above, let me know that as well and I will rethink my plan. Thanks in advance.
-Brandon
p.s. I did search, but I want fresh info. Maybe something better has come out recently that I don't know about and isn't on here yet. So if you're gonna post and say nothing but "use the search button" please save both of us some time and energy. Thanks again for any help and info offered.
Old Jan 18, 2007 | 08:01 PM
Raptor450's Avatar
I believe in these products: Stroker crank - Four Stoke Tech (fourstroketech.net), Piston - JE, Clutch Basket - Hinson, Gaskets - I always use factory gaskets with no problems yet. I like the Webcam camshaft better than the Hotcams.
ReconBayou
Oct 31, 2022 05:37 PM
Joe454
Nov 20, 2020 01:19 PM
r1pilot83
Utility ATVs
15
Nov 25, 2019 11:39 PM
r1pilot83
Sep 27, 2015 07:38 PM
black_thunder
Sep 22, 2015 07:59 PM
