oil in hubs
Old Dec 14, 2000 | 12:17 PM
MEANGREENMACHINE's Avatar
I have had problems now with my hubs not engaging or engaging when i don't want them too. I have read that you can use Mobil 1 synthetic oil in them instead of the polaris 4wd oil. What kind of synthetic oil it is? Is it 4 cycle oil, like a 10-4? Or is it a gear oil? Where can you buy it at? I would really like to get it fixed. Also my light for the 4wd isn't coming on at all. What could be the cause of that? Thankyou for your help.
Old Dec 14, 2000 | 12:27 PM
MagnumMudMan's Avatar
Mean
I will do the best to answer your questions. The oil that many recommend for the front hubs is Mobil 1 Synthetic ATF (Automatic Transmission Fluid). You can get it at about any auto parts store. The Polaris manual says you can run ATF if you choose not to run their product. As for the AWD light, it soulds like you have a bad/dirty connections somewhere. This could be causing some of the problems with your hub, such as not engaging. If the switch is not getting power, the hub will not be getting power and will not engage. I would check your wiring diagram and start checking the wires with an electric tester to isolate your problems. Maybe someone can post some more specific places to check as I haven't had any problems with the AWD and have never tore into it. Hope this helps.
Old Dec 14, 2000 | 12:35 PM
JBSPORTSMAN500's Avatar
Well I dont know about the Mobil1 oil, but I was told by a Polaris rep to use type F transmission fluid in my hubs on my Sportsman500. As for the hubs engaging and not engaging at time the oil it self is probably not going to fix that. Have you ever changed the oil in the hubs? Do you ride in deep water alot?
The light not coming on could mean that you have an electrical problem which could extend from the Magnetic Coil in the hub gone bad to the wires (wiring harness) from the grid to the hub having a break in them. I am not saying that this is your problem, but these are problems that I have faced in the past. The last time my hus engaged when I did want them to it was due to the water I had accumlated in the hubs that seized them together causing me to rip the teeth off the armiture plate on both sides.
So that is my suggestion on the oil in the hubs and a few suggestions as to if the oil does not fix your problem you might want to look at, and the hubs are nothing to fix 20 minutes a side.
Old Dec 14, 2000 | 12:49 PM
TheQuadfather's Avatar
My Scrambler riding buddy was having problems with only one of his hubs engaging. This was happening in two wheel drive mode. I drained his hub fluid, added the Mobil 1 ATF, and he hasn't had a problem since.
Old Dec 16, 2000 | 03:13 PM
OffRder15's Avatar
While we are on the topic, when I change the hubs, am I supposed to fill them back up at 3 o-clock or 4 o-clock?
Old Dec 16, 2000 | 05:00 PM
SWAC1's Avatar
I fill up the hubs at 12:00, and then rotate to 3 o'clock to drain excess. Object is not to fill them completely. I had occasional engagement with the AWD switch turned off, and had the space between the magnets adjusted by the dealer to I believe .001". Polaris needs to do some work on the hubs and the engagement.
rpaske's Avatar
i just talked to a dealer about changing my hub oil in my scrambler. he said do it in th e3 o'clock position and i used polaris hub oil and it seems to work bette that before since it would engage when i didnt want it to.
ride on
Old Dec 16, 2000 | 05:02 PM
rpaske's Avatar
yeah i just had that problem with it engaging. man was that making me mad!! how much did it cost you to get those spacers adjusted? but mine is now better with new hub oil but im sure it will happen again! thanks
Old Dec 16, 2000 | 05:33 PM
SWAC1's Avatar
I don't know how much the adjustment cost, 'cause I had all the brake pads changed as well. Although I rarely ever use the brakes since I have the EBS, wonder why I waited until 2800 miles to get new ones?
blueandy88
Sep 7, 2020 03:11 PM
jdunne01
Oct 4, 2015 10:29 AM
twon1235
Utility ATVs
Sep 7, 2015 04:38 AM
snowolson
Aug 31, 2015 03:51 PM
blueandy88
Aug 30, 2015 08:26 PM
