1984 big red will not move
Old Jan 21, 2007 | 11:12 AM
manfromtherock's Avatar
Default 1984 big red will not move
i got a 84 200 bigred shaft drive that was burning up plugs i changed the primary coil so that should fix that but now the bike starts but will not go into gear
Old Jan 22, 2007 | 08:36 PM
wrestleu's Avatar
Does it make any noise when you try to put it into gear? Did you put it back together right when you pulled the stator cover and put the new coil on? I'm assuming you had to pull the subtranny to get to the primary stator coil? I would start there....but I'm no expert on those fancy bikes w/reverse.
Old Jan 23, 2007 | 09:50 AM
it will shift into gear but will not engade the rear end it is like it is still in netural need help
Old Jan 23, 2007 | 11:21 AM
wrestleu's Avatar
Have you ever seen it ridden? Maybe the rear differential is stripped...that seems to be pretty common on the shaft driven atc's
Old Jan 25, 2007 | 05:27 PM
popup's Avatar
i had the same problem the axle.take it off the splins maybe stripped. if so good luck i still cant find one under $250 bucks.f@#k ebay payed for one and it never came lost $125us.
lonerider856
Oct 13, 2023 03:45 PM
Dewhound
Apr 20, 2017 02:25 PM
shimanok2
Jan 29, 2016 07:37 PM
Ahtatu
Sep 28, 2015 12:14 PM
Elkaholic
Sep 6, 2015 02:44 PM
