Problem with recon
Check and make sure that your choke isn't engaged or sticking. Also check the level of the motor oil because some Honda engines are are equipped with a switch that will shut the motor down when the oil level is insufficient. I would then clean and oil the air filter, replace the spark plug, and check your fuel filter (if your quad has one), and make sure that you are running fresh gas. If you still have a problem after doing these things get a compression gauge and run a compression check. Good luck.
