Problem with recon
Old Jan 22, 2007 | 10:23 AM
hondarodking's Avatar
Default Problem with recon
my 2004 honda recon keeps dying when i am riding it and if i wait a minute it will start back up. does anyone know what could be wrong with it
fourbor
Old Jan 22, 2007 | 11:08 AM
tubbby's Avatar
Check and make sure that your choke isn't engaged or sticking. Also check the level of the motor oil because some Honda engines are are equipped with a switch that will shut the motor down when the oil level is insufficient. I would then clean and oil the air filter, replace the spark plug, and check your fuel filter (if your quad has one), and make sure that you are running fresh gas. If you still have a problem after doing these things get a compression gauge and run a compression check. Good luck.
Old Jan 22, 2007 | 08:09 PM
mykool61679's Avatar
make sure the breather tube that goes from the gastank lid into the steering stem isnt pinched, iv seen it happen a couple times!
Firefighter400
Oct 8, 2022 06:38 PM
greg74
Sep 10, 2019 03:03 PM
ogio117
Polaris Side by Sides
Apr 29, 2019 03:14 PM
hondarider1234
Jul 21, 2015 11:53 PM
MNatv89
Jul 7, 2015 11:36 AM
