28 inch tires on 04 grizzly
Old Jan 23, 2007 | 08:46 PM
knauf's Avatar
Default 28 inch tires on 04 grizzly
I have a chance to pick up a set of 28 inch tires for my Grizzly. Is this a problem waiting to happen as far as putting too much stress on axles and drivetrain? Will I have to get a clutch kit? I have no problem putting a lift kit on it to help with the rubbing and I have read about people using clutch rollers from a Kodiak to make up for the larger wheels. Thanks.
Old Jan 23, 2007 | 08:50 PM
JLsparky7's Avatar
Your power is only as strong as the weakest link. Therefore I would definitely put some type of clutch kit on it. It may not be nesseccary right away but do it soon.
Old Jan 25, 2007 | 05:39 PM
Tugboat34's Avatar
I have two 2004 Grizzlys. One has 28" Mudlites, and the other has 27" Mudlites. I have broken a front axle on each, and a rear on the one with the 28's. I have never found any situation where the clutch was a problem on either machine. My Brother-in-law has an 05 Grizz with 27" Mudlites. He has snapped both rear axles but not a front.
The 28" tires will self-clearance your fender skirts, but they will not wear through. The 28's seem to go much better in all situations. They squash better at 2psi.
I hope this helps.
greg74
Sep 10, 2019 03:03 PM
Cantbuytime
Aug 17, 2015 06:33 PM
Cantbuytime
Aug 16, 2015 09:13 PM
Bergmann
Aug 13, 2015 03:51 PM
Jul 28, 2015 12:12 PM
