Kodiak450 won't start Just clicks, Help
Old Jan 27, 2007 | 04:02 PM
GBKODIAK's Avatar
Default Kodiak450 won't start Just clicks, Help
I have an o5 Kodiak 450 was running fine then I stopped it and now when I try to start it the relay under the seat clicks but the starte moter doesn't go. Any ideas where I should start looking for this problem. I did charge the battery and it is fine.
Thanks
Old Jan 27, 2007 | 04:06 PM
soccerboy's Avatar
If it is like the 350 Warrior it has several interlocks but it the starter is clicking then my guess is that its bad or hung up. Are you sure it is the starter clicking and not the starter relay?
Old Jan 27, 2007 | 04:08 PM
Oddy's Avatar
yea replace the starter relay its bad when the relay clicks but doesnt make the starter move,try replacing that and it shud be ok
Old Jan 27, 2007 | 04:12 PM
Speedy2222's Avatar
Is A Power Sport Junkie!
before u start replacing stuff.. make sure your battery is charged
Old Jan 27, 2007 | 04:48 PM
GBKODIAK's Avatar
I did charge the battery for a couple of hours and it seems ok, lights are bright etc. The click is the relay, sound is coming from somewhere near the back of the battery. Looks like I will need to remove the plastics to get to the connections and relay.
Unfortunately it is really cold here today so I may leave it for now.
Thanks for feedback.
Old Jan 27, 2007 | 05:27 PM
squeege's Avatar
Or you could just tighten the connections...my 2 cents
Old Jan 27, 2007 | 06:45 PM
crbm16's Avatar
8 out of 10 times this is the problem
Old Jan 27, 2007 | 09:06 PM
hondabuster's Avatar
Its almost never the relay, its a very simple device, and almost bulletproof. Try cleaning the mating surfaces at the battery terminal connection, and if that doesnt do it, have the battery load tested.
You can try hooking up a voltmeter, across the battery terminals, and watching how far the voltage drops while holding the starter button. If it goes below 10 volts, the battery isnt good and needs testing. Any auto parts store like napa will do it for free.
Old Jan 28, 2007 | 09:09 PM
SBuckJ's Avatar
Reconranger (automatics are for sissies)!
I agree with tightening the connections.I have a 450and the connections came loose after installing a cycle country electric switch. click click, no go
Buck
Old Feb 1, 2007 | 06:07 PM
CraZySteve's Avatar
OH Yea! I second what Squeege has said!! [img]i/expressions/face-icon-small-smile.gif[/img]
I took my 2007 Grizz 450 out a few weeks ago... it wouldn't start, the display blanked out... and nothing.. I was like [img]i/expressions/face-icon-small-disgusted.gif[/img] So I wiggled some wires and it started... So I went riding.. so during the riding I shut it down... didn't start again... wiggle wiggle.. and it started.. GRRR... I was like do I have a short in the harness? ?? ? So the remainder of the day I left it running...
End of the day... clean it down... go to start it and it fired up.. Nice...
Get home to unload it and Nothing.. GRRR Again... so I just roll it off - it sat in the garage... That night.. I was like DOH! let me check the wires on the battery... sure enough my Negative was loose! So I tightened that sucker up - even used some Purple (the wimpy stuff) locktite!
Mkp
Mar 28, 2020 03:50 AM
nature violator
Jul 3, 2015 08:40 PM
jayking232003
Jun 9, 2015 02:54 PM
bbehrendt
May 28, 2015 09:25 AM
1000gade
May 27, 2015 12:37 PM
