power cut out after roll over
Old Jan 29, 2007 | 01:20 PM
woodsrider823's Avatar
Default power cut out after roll over
I rolled my warrior over backwards a little bit ago. I stood it up let it sit, refilled all the fluids and it started right up. Since the roll over i have noticed that when I am in 6th gear pinned every once and awhile the power to the wheels cuts out and the engine revs. I let of the throttle then get back on it and its fine for another 30 seconds or so. I was just wondering if anyone had any ideas of what the problem could be. thanks
Old Jan 29, 2007 | 02:21 PM
Raptor660JC's Avatar
How long do you have 6th pinned down for? I overheard a mechanic in a yamaha dealership the other day telling someone who was having similar problems that you really shouldnt have the throttle pinned down for an extended period of time anyway b/c you will damage the engine and or blow the motor, you should be letting off the gas every so often.
I'm not saying this is your problem just something to consider.
Old Jan 31, 2007 | 11:21 PM
rruser's Avatar
Maybe you messed something up with your clutch lever/cable adjustment? How tight is your clutch lever now?
Old Feb 1, 2007 | 02:25 PM
I will look into the clutch lever and cable. The thing is it never cut out before the roll over so I am not sure that is my problem.
Old Feb 2, 2007 | 12:20 AM
recon99's Avatar
could be slipping out of gear. My warrior had a similar problem once, and the reverse linkage was out of adjustment.
2quiker
Mar 22, 2022 08:36 PM
mywifesquad
8
Sep 21, 2015 08:20 AM
toonces
Sep 5, 2015 01:14 PM
Pahuntman
Sep 5, 2015 11:07 AM
lancemll88
Sep 5, 2015 03:16 AM
