Warrior clutch not dissengaging?
Old Feb 1, 2007 | 07:00 PM
stringtwister's Avatar
Default Warrior clutch not dissengaging?
I have no free play in the travel of the lever and the machine still takes off when poped into reverse even with the clutch pulled all the way in? anyone know whats happening?
Old Feb 1, 2007 | 07:13 PM
Raptor350rider14's Avatar
take the little rubber thing covering the parts behind the clutch, loosen the little bolt till u have enough free play. that happens to me all the time. it sux
Old Feb 1, 2007 | 08:39 PM
Speedy2222's Avatar
Is A Power Sport Junkie!
did u take the rubber rings out when u replaced the clutch?
Old Feb 1, 2007 | 08:48 PM
I just bought it and haven;t done anything yet there is good lever travel and the clutch engages right at the end of lever travel.
Old Feb 1, 2007 | 10:58 PM
87warrior78's Avatar
on mine it does the same thing. i have talked to other people that own warriors and they say the same thing. it may just be a warrior thing just like the valves are loud.
Old Feb 1, 2007 | 11:31 PM
Speedy2222's Avatar
adjust your slack on the clutch perch..
Old Feb 1, 2007 | 11:40 PM
There isn't any slack, if there was the lever would move bevore the clutch arm right?
Old Feb 1, 2007 | 11:42 PM
I'm afraid if I go any tighter on anything the clutch will slip-It engages right at the end of lever release as it is.
Old Feb 1, 2007 | 11:52 PM
Speedy2222's Avatar
there should be slack in the cable between when it engages completely and when the clutch is fully out
Old Feb 2, 2007 | 12:21 AM
are you refering to the lever free play. there is 1/8 inch max lever travel before it pulls the cable. Tha original owner said it has been like that since new, I however wont settle for that. I want to beable to put it in nutrael without shutting it off and stopping in reverse with out doing the same-I've been riding since a little kid and fairly well no my way around a ride. I got all the possible clutch travel i can. I am wandering if there is somthing internal or something I am overlooking?
buddieboy
Dec 9, 2016 05:50 PM
tysonbully
Sep 28, 2015 02:30 AM
Barnsnelbon
Sep 27, 2015 03:07 AM
Bernhard
Sep 25, 2015 12:45 PM
jbrewster94
Sep 23, 2015 04:16 PM
