1995 polaris 250 trailboss start up problem
Old Feb 4, 2007 | 09:04 PM
trailridder's Avatar
Default 1995 polaris 250 trailboss start up problem
it is very hard to start all the time. i usually have to take the cover off the air box to get it to start after about 5 mins of cranking it over. when it stalls i have to repeat the process over and over. if anyone can help me id really apriciate it.
Old Feb 4, 2007 | 10:06 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
if you pull the plug is it dry, or wet from flooding? maybe the fuel filter is plugged, as well as the carb. being dirty.
Old Feb 5, 2007 | 08:02 AM
ok thanx ill try that. and i have another question what do they mean by rejetting the carb.
Old Feb 5, 2007 | 08:06 AM
stendori's Avatar
Super Quad Patrol
I'm watching you!
rejetting is putting differnt size jets in(mostly bigger) allowing more gas to flow in. you dont need to do this w/ a stock bike. chances are like i said maybe its dirty? how does it run once it starts and goes?
Old Feb 5, 2007 | 08:14 AM
once it starts up it idles fine but like i said once it stalls its ahrd to start again.
Old Feb 5, 2007 | 08:26 AM
stendori's Avatar
Super Quad Patrol
I'm watching you!
why is it stalling? when you try to take off will hit the throttle?
Old Feb 5, 2007 | 08:29 AM
sometimes i have t pump the throttle so it wont stall but othertimes it will idle fine. most of the time it stallls when it sits for a min or 2 just idling
Old Feb 5, 2007 | 08:38 AM
stendori's Avatar
Super Quad Patrol
I'm watching you!
but does it run fine on the trail? i would change the fuel filter if its old and maybe clean the carb. if its idled to low just turn it up a little.
Old Feb 5, 2007 | 10:04 PM
ok thanx yea ill try all that
TJM
Jun 11, 2015 01:28 PM
Steven Bandemer
Jun 9, 2015 08:50 PM
1000gade
May 27, 2015 12:37 PM
kencbs
May 23, 2015 05:29 PM
willster
Mar 12, 2000 11:17 PM
