thermostat test
Is there anyway to test a thermostat. I have a fan that isn't kicking on and I am doing a process of elimination. I had coolant running out or the reservoir the other night and some of the help that I got from an other post was to check the thermostat, them move on to the fan swith. I got the thermostat out and would like to know how to test it.
if you have the thermostat out in your hand you can put in a pan of boiling(almost) water and you should see it open up. if it does you know it works im not sure the temp is that opens it but assuming at least 160.
kbazzy
Sep 26, 2015 11:26 AM
TheATVSuperStore.com
TheATVSuperStore
Sep 9, 2015 07:43 PM
