thermostat test
Old Feb 7, 2007 | 06:52 PM
3607race's Avatar
Default thermostat test
Is there anyway to test a thermostat. I have a fan that isn't kicking on and I am doing a process of elimination. I had coolant running out or the reservoir the other night and some of the help that I got from an other post was to check the thermostat, them move on to the fan swith. I got the thermostat out and would like to know how to test it.
Old Feb 7, 2007 | 07:13 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
if you have the thermostat out in your hand you can put in a pan of boiling(almost) water and you should see it open up. if it does you know it works im not sure the temp is that opens it but assuming at least 160.
Old Feb 7, 2007 | 11:46 PM
GarryESE's Avatar
Should be full open at 190F.
Old Feb 8, 2007 | 12:11 PM
troylee07's Avatar
i had that problem and it turned out to be dirt lodged in the fan i took out the fan and hooked it up to a car battery and it broke the fan loose because it runs fine now.
Joe454
Nov 20, 2020 01:19 PM
kbazzy
Sep 26, 2015 11:26 AM
95scramblerruben1033
Sep 23, 2015 06:29 PM
Nosniborpapa
Sep 12, 2015 05:54 PM
TheATVSuperStore.com
TheATVSuperStore
Sep 9, 2015 07:43 PM
