1999 wolverine runability
Old Feb 9, 2007 | 12:48 PM
gizmotor's Avatar
Default 1999 wolverine runability
Purchased from friend at work it has been outside for 1 1/2 years.
With a bunch of work and cleaning finally got started.
Slide gate in carb is not moving.
What forces gate to move ?
Old Feb 9, 2007 | 01:03 PM
gizmotor's Avatar
Also does anyone have carb for sale?
Old Feb 9, 2007 | 05:15 PM
ctateusa1's Avatar
check on ebay
There is always a lot of parts for the wolverine 350 for sale on there.
Old Feb 9, 2007 | 10:25 PM
95wolv's Avatar
The slide on the carbs of 96 and up Wolverines are vacuum operated, there is a diaphram on the top of the carb that lifts the slide, it is possible that your diaphram has dry rotted and has a rip or hole in it. Take the top off the carb and check out the black rubber diaphram to see if it is clean and sealed up.
Old Feb 10, 2007 | 03:17 AM
rruser's Avatar
The slide on that carb wouldn't move unless the motor is running. I'm guessing it didn't work either way.. But I just wanted to make sure you knew.
Old Feb 10, 2007 | 07:53 PM
gizmotor's Avatar
Thanks for everyones help.
I will let you know!
rockinkgin
Sep 25, 2015 01:52 PM
Steeldon
Sep 9, 2015 09:38 AM
Steeldon
Sep 8, 2015 10:51 AM
spark1051
Utility ATVs
Sep 4, 2015 07:58 PM
GirlsCan2
Technical and How-To Articles
Aug 27, 2015 02:58 PM
