No Spark 600 Sportsman
Old Feb 11, 2007 | 01:31 AM
HeavyDee's Avatar
Default No Spark 600 Sportsman
I was doing a little bit of plowing and on the way from my neighbor's house to mine the wheeler just died, no clunck, no thud, just blahhh.
It will turn over, lights work etc. After putting it in the heated garage for a day to make sure nothing was frozen I cleaned it up and just looked for anything that may be obvious...well first, one of the plug wires was actually off of the plug, I put it back on, still nothing. Pulled both plugs, checked to see if I got spark but didn't see anything. The old ones were shot anyway so got two new ones, checked for spark on the engine block again and nothing...figured I would put them in and check for the heck of it...would not start...so, pretty sure it's electrical. Now to work my way back, that's the hard part, I'm not that great with electricity but I do have a meter and would like to start doing a little diagnostics. Please let me know if you have a good process for me to check through the components. Thanks
Oh, I could probably use to get a book so I know what the readings should be, any suggestions?
Old Feb 11, 2007 | 07:49 AM
stendori's Avatar
Super Quad Patrol
I'm watching you!
well did the kill switch didnt get turned off? sounds silly but sometimes. dont know if it has 2 coils or one but the coil could have gone, the staor might be fried, could have sheared off the key way on the fly wheel, electrical is the harest thing to find.
Old Feb 11, 2007 | 09:49 AM
HeavyDee's Avatar
No, I checked the switch, I've had that happen when I was like 10 and haven't forgoten it since, my father busted on me so bad because I was affraid to tell him the 4 wheeler broke and all it was is I had hit the switch...over the next 20 years I've learned a few things but I can't say I've ever had an electrical problem on my sleds or wheeler. I'm going to get my multi meter from work today and start trying to test, just don't know what to expect.
It has one coil, I figure it could have gone but I want to check it befor buying one. I don't have spark at the end so I figure I can work my way back to see where the power stops flowing.
Old Feb 11, 2007 | 11:18 AM
jta4455's Avatar
There are actually two coils in one located under the left front fender. All a person can do with that is check the resistance in and out of that. It would help if you had a polaris manual for the machine to be able to check the resistance measurements to your stator. Ohh your plug caps should have about 5k ohms of resistance.
Old Feb 11, 2007 | 05:06 PM
Polaridoo's Avatar
Working back from the plugs it could be the high voltage coil, the ignition module, the stator, or the pickup coils. If you need some specs and don't need them in a hurry I can look them up for you.
Old Feb 11, 2007 | 08:48 PM
HeavyDee's Avatar
I could use the specs but I did read on another forum here that there is a guy that has the manuals on cd on ebay for approx. $16 as opposed to the book I priced today around $80 so I may look into that. I have a multimeter but most of my problems are I'm not good at using that either so really I'm out of my league but I'm trying. Any info will be helpful.
Jmuddin284
Jan 19, 2026 07:16 AM
Johnclay
Utility ATVs
Jul 19, 2015 10:00 AM
Gtsordo
Jul 13, 2015 10:38 PM
Shifts
14
Jul 13, 2015 08:41 AM
sublime250
1) Engine problems..
Jul 11, 2015 11:52 AM
