2002 Scrambler 400 Problems
Old Feb 12, 2007 | 12:35 AM
Steal's Avatar
Default 2002 Scrambler 400 Problems
I have a 2002 Scrambler 400 that is leaking coolant out of a hole near the water pump. In addition, you can only go in reverse when you hold in the overide button, without holding the overide the engine bogs down. Please help!!![img]i/expressions/face-icon-small-confused.gif[/img]
Old Feb 12, 2007 | 12:51 AM
scrammersam's Avatar
the reverse thing is the way they are, safety thing. i overrode that by pulling a purple wire coming from the shifter.
coolent thing im not sure on
Old Feb 12, 2007 | 10:23 AM
klier's Avatar
Sounds like you've got a water pump seal that's gone south. Water pumps are designed to weep coolant at this hole when the seal starts wearing out.
Did you buy the Scrambler new or used? If a different primary clutch spring has been installed, it wouldn't be at all unusual for it to bog down in reverse without the override button. That is how mine operates after I went with an aftermarket pipe and clutching...
Old Feb 12, 2007 | 11:35 AM
Steal's Avatar
The Scrambler was new when we bought it. We use to be able to go in reverse with no problems, now we need the overide button. Also when you go in to reverse the green 'R' light will fade out almost like the bike is lacking power, could this be a battery issue? It has been a long time since we were able to start the bike using the key, we have to pull start.
maxjung
Jul 13, 2015 05:11 PM
Chocobamofo
Jul 10, 2015 07:46 PM
coolguy420
Jul 10, 2015 01:17 AM
cSchwartz
Jul 9, 2015 02:43 PM
MNatv89
Jul 7, 2015 11:36 AM
