xplorer 400 shift problems
Old Feb 25, 2007 | 08:48 PM
trigger2458's Avatar
Default xplorer 400 shift problems
I'm new and have read alot of helpful posts about common problems but have not seen one for my problem. I just bought a 400 xplorer 4x4 and every now and then when i try to shift into high or low it grinds. I can put in reverse and then back into high or low and it works fine.
Old Feb 25, 2007 | 09:14 PM
Kawiking33's Avatar
The trany gears are all chewed up. Try to completely stop to shift it from now on. Change the tranny fluid a lot also to clean out the shavings accumulating probably.
Old Feb 25, 2007 | 09:50 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
some times if its idled to high as well or if you put it gear slow.
Old Feb 25, 2007 | 09:58 PM
ftwflh's Avatar
The main reasons for grinding going into gear is 1. the bell crank on the tranny is worn or stripped
2. idle is too high
3. shift fork is worn
4. rod is out of adjustment
hondarider1234
Jul 21, 2015 11:53 PM
KimSJoh
14
Jul 18, 2015 07:20 PM
Scottma518
Jul 16, 2015 09:19 PM
cornermike
Jul 8, 2015 11:44 PM
sara durrant
Jul 6, 2015 05:32 PM
