Studding tires
Old Feb 26, 2007 | 04:20 PM
SickSixtyRider's Avatar
Default Studding tires
Has anyone ever put snowmobile studs through a atv tire from the inside and then put a tube in? My stock tires are wore out and I was wondering if the tire is strong enough or will the studs just rip out?
Old Feb 26, 2007 | 04:37 PM
yz426ex's Avatar
If you put them in then cut a piece of carpet and put it in the tire so the tube dont get a hole in it. I seen alot of people run like that.
Old Feb 26, 2007 | 05:35 PM
Doesn't the head of the stud counter sink into the tire when u tighten the nut? Then the tube shouldn't rub on any sharp surfaces. How long of studs do people get? I don't want anything more than 1/4" to 3/8" sticking out past the tire *****.
Old Feb 26, 2007 | 05:59 PM
deanz400's Avatar
read an artical about studding tires like your talking about and your right about the length because you still want the rubber to contact the ground .
Old Feb 27, 2007 | 11:25 AM
yz426ex's Avatar
They look like a inch above the rubber from the pics I saw. For them to work best put them in rows of three but slanted not streight across.
Old Feb 27, 2007 | 05:38 PM
An inch above the ***** or the casing of the tire?
Old Feb 27, 2007 | 10:56 PM
quadsport230's Avatar
what are snowmobile studs, like regualr metak snow studs?
Old Feb 27, 2007 | 11:28 PM
deanz400's Avatar
the info I read was from a guy that ice races and you don't want to much stud above the **** because if you get on asphalt or such you can loose control .
Old Nov 18, 2009 | 08:20 PM
yamaha 4 life's Avatar
yeah, does anyone know what its like with the snow mobile studs i wanna do that with the tires on my banshee and was wondring if it would be allright to do that im just gunna be running on lakes and snowy trails thanks
Old Nov 19, 2009 | 04:53 PM
tramp's Avatar
Why not stud them with snow tire studs. Just drill into the **** the dept of the stud and insert them with a stud gun. Easy, have done several car and truck tires, should work on an ATV tire as well.
