scrambler 50 tires
Old Dec 19, 2000 | 02:10 AM
4wheelindakota's Avatar
i cannot find 16" tires for my kid's scrmabler.
the stock ones are knobby junk. all available 16" are also knobbies. any ideas?
Old Dec 19, 2000 | 04:05 PM
snowshark's Avatar
B-ret,
You will need to get an 18 inch tire in order to get a good tire. You will need new rims for these tires. Are you looking for rear tires only or front & rear. You probably only need rear tires. The stock tires that come on kids quads are not very good.
We had a problems with the tires filling up with mud in between the knobbies before going to a better & bigger tire on our E-ton.
In an 18 tire you can get shredders, fast trakkers, hole shots just to name afew.
Gauge will lose some speed by going with a bigger tire, but the bigger tire, which will also be wider than stock, will make the quad more stable when rideing.
Old Dec 19, 2000 | 04:24 PM
00TB250's Avatar
I'm no tire expert, but wouldn't a larger tire actually increase speed but reduce torque?
Old Dec 19, 2000 | 04:49 PM
snowshark's Avatar
You would usually gain speed by going to a bigger tire, but in the case of kids quads the extra speed (increased tire size) is off set by the additional weight of the tires. One these kids quads not only do you go larger diameter but they are also wider.
The speed loss should not be a lot, but there will be some.
Old Dec 19, 2000 | 05:01 PM
00TB250's Avatar
Ah! Got ya...
Thanks for the clarification.
Old Dec 19, 2000 | 06:54 PM
Sportsman6x6's Avatar
Here is what ya need(this is all in my mind, forgive me but I am a mud rider and often daydream when I have nothing to do). Trade that SC50 in for a Sp90, lift it, put bigger tires on it(mud tires), run spacers, snorkel it, run a straight pipe lol, Bore it out, put in a low end cam and convert to a 4wd. Just a few things to name, but you have to admitt that would be pretty cool if it were possible.
fordfaithful21
Dec 7, 2015 05:52 PM
89Lt250r
Sep 7, 2015 07:53 PM
switzomatic
Aug 24, 2015 12:57 PM
mitchxc700
Aug 19, 2015 02:41 AM
maxjung
Jul 13, 2015 05:11 PM
