gas tank dent
Old Dec 19, 2000 | 11:26 PM
fd124's Avatar
I've got a friend that has a Big Red that has a dent in the gas tank. It's just above the seat so you can't get a suction on it with the X it has built into the tank from the factory. Any other suggestions?
Old Dec 19, 2000 | 11:41 PM
waynaferd's Avatar
Your probably gonna hafta drill a small hole and use a dent puller on it to remove the dent. Then put a little JBWELD on it to seal the hole, sand it smooth, and squirt some paint on it.
Old Dec 20, 2000 | 02:50 PM
bluGill's Avatar
Other then the drill hole and pull, you can sometimes seal the tank, and use compressed air to push the dent out.
Don't add air too quick, you want just enough to push the dent, too much will explode the tank. Assuming you can get enough of a seal of course, which is hard.
Can you live with it? Call it a battle scar and show it off. I have a small dent in my 200s, but it doesn't subtract much fuel capacity and I really don't care.
If all else fails, a little bondo and some paint can cover it up. AT least I think so, I have never been close to a big red so I can't tell where the dent it or what it would affect by your description.
Old Dec 20, 2000 | 03:53 PM
WJW's Avatar
WJW
You could try an old trick, fill the tank almost full of water and put it in the freezer, the water will expand about 20% as it freezes. If you git it right that will push the dent out, If you put too much water in you could split the tank so start low and work up till the dent is gone. Water is better than air presure, If the tank explodes with air you may die with water you will only need a new tank Good Luck WJW
wrencher82
Sep 30, 2015 04:27 AM
wrencher82
Sep 28, 2015 10:02 PM
2many2ride
Sep 27, 2015 04:35 AM
wrencher82
Sep 24, 2015 03:39 PM
MikeyBoyesq
Sep 22, 2015 10:02 AM
