trail blazer brakes
well it appears i take better care of my sporty than i do mama"s trailblazer.. we went for a small ride to day and when we got back the rt frt caliper was leaking fluid / and had no brakes.. pulled the tire off and it been a while since i checked the brakes..the rear pad was GONE as in not there, the piston was over extended and ground very bad on the rotor.... can i get just a pison and a re-build kit........ thanks guys
ok got it apart , can i just replace the seals ... the end is ground off about 1/4 inch but the sides are not scratched up .. the more money i spend on this is less for mine!!!!!!!!!!
just remeber when you put it back to together that all the brakes will have to be bleed most likey.is it much more w/ the new piston vs just the seals? i noticed theres like an end cap of sorts in the parts breakdown, is that what wore down? at the worse it would be pushing out to its limit and may pop out at worse case. who knows maybe it would be fine.
SixSpeed5
8
Aug 2, 2015 05:38 PM
willday08111217@gmail.com
Technical and How-To Articles
Aug 1, 2015 04:05 AM
