trail blazer brakes
Old Mar 18, 2007 | 04:04 PM
onesavage's Avatar
Default trail blazer brakes
well it appears i take better care of my sporty than i do mama"s trailblazer.. we went for a small ride to day and when we got back the rt frt caliper was leaking fluid / and had no brakes.. pulled the tire off and it been a while since i checked the brakes..the rear pad was GONE as in not there, the piston was over extended and ground very bad on the rotor.... can i get just a pison and a re-build kit........ thanks guys
Old Mar 18, 2007 | 04:12 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
here is the repair kit number PISTON & SEAL,KIT ** (Incl. 4-7)
1930665 1 $30.57.
Old Mar 18, 2007 | 04:14 PM
onesavage's Avatar
SWEET, stendori you truely rock man[img]i/expressions/face-icon-small-happy.gif[/img]!!!! were is that from if ya could.......
Old Mar 18, 2007 | 04:16 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
ronnies.com
i would check the dealer price inyour are to see how much more if any it would be. i beleave thats the oem polaris no#
Old Mar 18, 2007 | 04:26 PM
Fenton88's Avatar
same happened to me i got the piston and seal kit..make sure to put some sil glide on the rings and the piston so it slides in nice and has good movement
Old Mar 18, 2007 | 04:29 PM
onesavage's Avatar
how do ya take it apart, get the piston out?????
Old Mar 18, 2007 | 06:27 PM
onesavage's Avatar
ok got it apart , can i just replace the seals ... the end is ground off about 1/4 inch but the sides are not scratched up .. the more money i spend on this is less for mine!!!!!!!!!!
Old Mar 18, 2007 | 08:07 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
just remeber when you put it back to together that all the brakes will have to be bleed most likey.is it much more w/ the new piston vs just the seals? i noticed theres like an end cap of sorts in the parts breakdown, is that what wore down? at the worse it would be pushing out to its limit and may pop out at worse case. who knows maybe it would be fine.
STLyamwar
Jul 25, 2020 04:44 AM
SixSpeed5
8
Aug 2, 2015 05:38 PM
willday08111217@gmail.com
Technical and How-To Articles
Aug 1, 2015 04:05 AM
Nondem
Where to Ride
Jul 23, 2015 07:38 PM
Gnuters
Jul 19, 2015 10:03 AM
