Outty800 Excessive noise in rear end
Old Mar 19, 2007 | 05:02 PM
OneFlyCowboy's Avatar
Monkey Rider
Afro-Engineer
FREE AND NOW are the best
Default Outty800 Excessive noise in rear end
So the last few times i have ridden the outty i have noticed the rear end is sorta Howling when on the throttle or off. if you kinda hold it in the coast position no noise. It was bad enough sunday morning I put it up on blocks and ran it to isolate the noise. definatly comming from the rearend. Checked the oil and its pretty stinky but still full. and don't look like it has been contaminated. i really don't remember the rearend bein that loud so im thinkin there has to be sompin up. Is this sompin that would be a warrenty issue? as its commin up on 1 year...
Old Mar 19, 2007 | 05:19 PM
DSNUT's Avatar
Treat it like it is a warrenty issue until they prove that it is not....imo
Old Mar 19, 2007 | 05:38 PM
Monkey Rider
Afro-Engineer
Thats the plan. tell em its their problem.. im just kinda wonderin what the heck the problem could be. maybe a tooth missin on the ring gear? or maybe a bearing is out somehwhere in the rear diff. it has a bunch. there is a lil slop in axles. Like play in the axles. or you can hold the one tire and rotate the other a lil bit. its just wierd. makes a guy nervous drivin it round not knowin what it is. doesnt seem to hinder the performance any.
Old Mar 19, 2007 | 08:12 PM
DSNUT's Avatar
Based on what you are describing I bet it is getting hot. Differential oil is always stinky, lol........but it is REHEHEHEALLY stinky when it is burned from a bearing that is going to pot.
Have you noticed a decrease in power when it starts humming?
Old Mar 19, 2007 | 08:17 PM
deanz400's Avatar
Take it in for warrenty issue
Old Mar 20, 2007 | 01:09 PM
Monkey Rider
Afro-Engineer
Nope. no decrease in power. It rides completely normal. Like i said when you get to a balance point like relieve the tension from the gear it makes no noise when your on the throttle or off the throttle you get the noise.
As for stinky when i cracked the plug i could start to smell it. well i pulled the plug. it was rank..
Just take it i guess and let the dealer check it.
Old Mar 21, 2007 | 11:44 AM
Monkey Rider
Afro-Engineer
Its in the shop..
I have heard rumor from a friend in the industry that the 05-06 rearends were standard threads on the input gear shaft or whatever its called.. so when its in drive it can back the threads out and loosen the gear making it chatter against the ring gear. the 07's and later are rumored to be a reverse threaded doohicky to prevent this. Dunno what they are gonna do for the fix. but asked them to replace the rearend and seat and come up with a fix for the seat melting as that shoulnd't happen. weeeeee.
Old Mar 23, 2007 | 12:56 PM
Monkey Rider
Afro-Engineer
So the dealer took the rearend apart and indeed it was the pinion shaft bolt doohicky had backed out. they tighted it back up but it had worn the gears and is still makin noise.. So an updated 07 rearend will be goin in. No outty to ride this weekend [img]i/expressions/face-icon-small-sad.gif[/img]
Old Mar 31, 2007 | 04:19 PM
Squirtis's Avatar
Originally posted by: OneFlyCowboy
Its in the shop..
What year is your outty..... i just picked up my 07 on wensday and there is a howl coming from somewhere.....wonder if its the same sound.
Old Mar 31, 2007 | 09:29 PM
maxxedouty's Avatar
Sounds like it should be covered.Isnt your warranty for 3 yrs? How many miles do you have on it? Penland blew a rearend in the Baja 1k.
greg74
Sep 10, 2019 03:03 PM
mywifesquad
8
Sep 21, 2015 08:20 AM
black_thunder
Sep 7, 2015 01:24 AM
OutRacing
Technical and How-To Articles
Sep 3, 2015 07:49 AM
snowolson
Aug 31, 2015 03:51 PM
