What do I use to change rear gear fluid?
Old Mar 25, 2007 | 10:47 PM
NHarrison2's Avatar
Default What do I use to change rear gear fluid?
I changed the front gear lube, oil change and trans oil but I can't seem to find what to use for rear gear box? 05 sportsman 700 efi. Please help. Thanks.
Noble
Old Mar 26, 2007 | 01:18 AM
JCDEYO25's Avatar
Noble....
ATV Angle Drive Fluid
or
80W-90 Gear Oil
John
Old Mar 26, 2007 | 07:10 AM
stendori's Avatar
Super Quad Patrol
I'm watching you!
just so you'll know front/back both only take 5ozs and tranny takes 15 ozs. jcd is right on what it takes. the important one is to make sure you used drive hub fluid for the front gearcase. or the awd will give you trouble.
Old Mar 26, 2007 | 07:22 AM
SAshton's Avatar
the book says 5 ounces but everyone says to fill to the bottom of the fill hole. Mine takes 8-10 ounces to fill to bottom of the fill hole. (2003 700) anyone else think 5 ounces just isn't enough?
Old Mar 26, 2007 | 07:45 AM
Kerbbirds's Avatar
I fill them to the fill hole.I also use synthetic 80-90 in the rear.
Old Mar 26, 2007 | 01:57 PM
NHarrison2's Avatar
Thanks for the info. What brand of oil do you all suggest for the rear?
Noble
Old Mar 26, 2007 | 06:12 PM
SAshton's Avatar
I use the Polaris Angle Drive Fluid.
Old Mar 28, 2007 | 01:55 PM
redmtn's Avatar
I hope you used the on demand front diff fluid for your front diff. The dealer didn't on my 2004.5, he got confused with the 2004 that used gear oil. My front diff was ruined and they were never able to fix it. All new hillards use the "On Demand diff fluid." Check your manual.
coolguy420
Jul 10, 2015 01:17 AM
sara durrant
Jul 6, 2015 05:32 PM
yambam13
Jul 4, 2015 01:49 PM
joe blo2
Jun 7, 2015 10:54 AM
