99 Xplorer 300 wont stay running while in gear. HELP!!!!
Old Mar 31, 2007 | 04:45 PM
TeamYZF's Avatar
Default 99 Xplorer 300 wont stay running while in gear. HELP!!!!
Hey guys, I am new to this forum.. We were out riding yesterday, my friend was on my dads 99 Xplorer 300.. About halfway through the ride, he was going through some water that was maybe up to the foot boards and it stalled.. Had to start it in neutral, and when he tried to shift it into high gear it stalled out.. Started it in gear but had the throttle pushed in a bit and it went fine.. Seemed like there was a belt slipping somewhere, but this is chain drive? Might i add that the thing idles fine while in neutral. Speaking of chains, we just got this thing back from the shop, had a brand new chain put on it.. I dont think that has anything to do with this but maybe it does? But anyway, we get it home and when you stop, the thing dies. I lifted up the rear tires, and it goes fine when in gear (high low or reverse), but once the tires hit the ground it stalls out if the RPM's arent high enough.. When you put it into gear, the RPM's go way down, and instantly the tires start to move.. To me it seems like the clutch is engaging way too low. Has anyone had this problem before?? It just started happening in the middle of the ride.. It goes fine when you are on the throttle, let off and stop, it stalls out. Please help!!
Old Mar 31, 2007 | 04:55 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
team. welcome to the forum fellow mainer. it sound like its time to pull the clucth cover off and take a look. th echain has nothing to do w/ it and yes its a belt drive clutch system. if you pull the cover off you can watch what its doing while in gear/neutral. becareful moving parts. but first thing is it idled too low by any chance?? turn up the idle any some and it should stay running. if you do this and when you put it in to gear and it starts to crep foward then theres something wrong w/ the clutches or belt.
Old Mar 31, 2007 | 05:14 PM
TeamYZF's Avatar
It isnt idling too low i dont think, it seems to be fine.. It idles fine in neutral, but not when its in gear.. I turned up the idle a bit, but it still did the same thing while it was in gear.. It does this no matter if its in high, low, or reverse.
Old Mar 31, 2007 | 05:32 PM
TeamYZF's Avatar
I did a search and i found that this happened to a guy with a sportsman 500, he said he was shimming out the secondary.. Could this be the problem??
Old Mar 31, 2007 | 10:44 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
mr. team, (sounds professional lol.) i would recommend taking the clutch cover off and take a peak. you have to anyways to check all the above and seeing is beleaving.when you get if off and watch what its doing maybe tells us and maybe we can give some direction to go.
Old Apr 1, 2007 | 11:01 AM
TeamYZF's Avatar
Ok, thanks a lot Stendori! I appreciate it.. Ill take a look at it later today!
MikeyBoyesq
Nov 27, 2020 02:44 PM
Big600twin
Jun 10, 2015 03:01 PM
jayking232003
Jun 9, 2015 02:54 PM
winterwolf
ATC 3-Wheelers
Jun 3, 2015 07:34 PM
cornermike
May 27, 2015 10:04 PM
