Smoking 250 ex
Old Apr 10, 2007 | 10:54 AM
superintendent's Avatar
Default Smoking 250 ex
Guys your help here would be deeply appreciated. I am trying to troubleshoot a 2005 250ex that has great compression (190) and I have just changed the valve seals and re-assembled the motor. Prior to my work there was a smoking problem upon acceleration. Now that I am done there was no smoking upon re-start and initial run. Then I changed the oil and the smoking started again. The engine runs real strong and I find it hard to believe the rings could be bad. This is a four stroke motor.
Any help will be appreciated.
Superintendent
Old Apr 10, 2007 | 10:18 PM
ryan1111's Avatar
put some clean oil down your spark plug hole if the compression goes up you got bad rings if it doesnt go upits soemthign else prob bad valves i have the same problem but mine doing the same thing kinda but it onlt has 60 lbs compresion but runs llike brand new after a new 10over pistion and new rings
Old Apr 10, 2007 | 10:26 PM
Ryan, thanks for the input, I am going to take the head and cylinder to the local shop and have the guides changed and have the cylinder measured to see if I need to go oversized.
Thanks again, Superintendent
xreynolds95
Technical and How-To Articles
Nov 19, 2024 03:52 AM
EIF
Apr 20, 2017 07:15 PM
CosmoM
Sep 21, 2015 04:57 PM
bvolks
Sep 13, 2015 12:57 PM
