no awd......help needed !!
Old Apr 11, 2007 | 11:03 AM
colt2245p's Avatar
Default no awd......help needed !!
i have an 01 sp500. the switches on the trans are bad therfore i have no awd. yes everything on my speedo works fine. i have no indicator lights f/n/r. i removed switches to inspect and the plastic piece that works the switch is broken on both swithes. i dont want to spend the 120 bucks for new switches. can i bypass and manually enguage awd ? i have read about splicing wires together to bypass. thnaks
Old Apr 11, 2007 | 05:05 PM
colt2245p's Avatar
i have been searching and found some info in another forum is this correct??????? remove brown/white wire from six pin connector at back of speedo and ground out. by doing this would it make the speedo not work as it does now??????
Old Apr 11, 2007 | 05:38 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
i read that same thread somewhere, try it and see what happens.
Old Apr 12, 2007 | 09:48 AM
colt2245p's Avatar
found another way to do it. since my speedo functions correctly and i dont want to mess with it i figured out witch two wires send the signal that im in forward from the switch to the pod and spliced them together now the thing thinks its in forward all the time. speedo still works awd works and there is no reverse limiter when in reverse ...
Sjrpp
Jul 5, 2015 09:04 PM
traumajunkie
Jul 5, 2015 03:03 PM
tweeder
Jul 5, 2015 01:57 PM
Mphillips
Jul 2, 2015 07:20 PM
