need help with reverse parts
Old Apr 13, 2007 | 12:26 PM
honda85's Avatar
Default need help with reverse parts
i have 85' 250es bigred need to know what parts i need so reverse can work no left brake lever with attachment any help would be helpful thanks[img]i/expressions/face-icon-small-confused.gif[/img]
Old Apr 13, 2007 | 02:01 PM
Biggiefl's Avatar
Should be REAl easy to find that on E-Bay. 250sx is the same part a well. The little red button can be bought at your dealer for $3 so don't get caught buying one on e-bay for $10-15. There is a cable as well for that lever that attaches to your trans through your side case, if you don't have that connected, might be a biotch to hook up but I doubt it.
Old Apr 13, 2007 | 11:21 PM
honda85's Avatar
i thank you for the feedback i will check that out, i should've known that but caught up in everything else,i'm sure i will have more questions later thanks again[img]i/expressions/face-icon-small-smile.gif[/img]
Old Apr 17, 2007 | 05:57 AM
honda85's Avatar
i don't see where the reverse cable goes on transmission , also it has a kein carb can that be changed to a mikuni thanks[img]i/expressions/face-icon-small-sad.gif[/img]
Old Apr 17, 2007 | 04:04 PM
Biggiefl's Avatar
I will double check where cable goes but I know there are 2 cales coming out of the left handset. As fara s carb goes, stick with stock. These are not very powerfull machines so changing carbs will do nothing for you except drain your wallet.
Old Apr 17, 2007 | 09:32 PM
honda85's Avatar
i'm asuming two cables 1 for brake 1 for choke someone said 1 for reverse ,, on microfich it shows 3 cables, which would make sense, also i probly will stick with kein carb just need to get side cover and maybe rebuild kit , i found 1 for$ 24.00 wich includes everything some other little parts but its just a hobby thanks again.[img]i/expressions/face-icon-small-cool.gif[/img]gotto spend money somewhere before it goes into snowmobile again.
Reactant
Mar 30, 2022 02:08 AM
ScopeZ_
Jul 28, 2015 01:44 AM
Schneider
Jul 24, 2015 05:05 PM
Derek Allen
Jul 22, 2015 09:25 PM
Scottma518
Jul 10, 2015 12:42 AM
