what is a heelclicker clutch kit?
Old Apr 15, 2007 | 04:39 PM
crazy1291's Avatar
Default what is a heelclicker clutch kit?
is it like a second brake pedal on the left side of the quad (where the shifter is on manual quads)
Does it do the same thing as a clutch/clutch lever on a manual quad or dirtbike?
Old Apr 15, 2007 | 05:17 PM
Instigater's Avatar
It is an adjustable clutch kit. It replaces the flyweights, in a PVT clutch system. The flyweights are adjustable, to tune your clutch the way you want it to run!
Old Apr 15, 2007 | 07:22 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
its made to adjust your rpm engaugment and there it shifts out. consist of springs, weights, and screws(adjustable weights) ans instructions.
Old Apr 16, 2007 | 06:58 PM
crazy1291's Avatar
but does it work like a manual clutch? or is it just another clutch kit for polaris utes? (why would those jerks call it heelclicker then?)
Old Apr 16, 2007 | 07:04 PM
suds's Avatar
It is not like a manual clutch. With a clutch kit you will ride and operate your machine exactly the same as before.
The main thing a clutch kit will do is change the RPM range which your clutch engages at.
For Example: When in Drive on your quad you do not move until you hit the gas. Lets say you start moving forward at 1000 RPM. With a clutch kit you will not begin to move forward until your motor hits 2000 RPM. The benefit to this is get the increased horsepower that you motor is making while still moving relativley slow, you may call this having more bottom end.
The RPM's which I used in my example are not actual.
Old Apr 16, 2007 | 07:08 PM
suds's Avatar
Heelclicker is just an aftermarket brand name.
Old Apr 16, 2007 | 07:55 PM
crazy1291's Avatar
wouldnt it be nice though if there was a "clutch" available for cvt quads that could disengage the transmission so that you can just coast at 10mph- fullthrottle- then lift your heel again and POP- the front end comes up....... i hope some company makes this as it would make scamblers, tb's, kfx700s, and renegades a lot more fun to ride, and a lot better for trails
Old Apr 16, 2007 | 08:56 PM
brutus450's Avatar
i bet you would flip it if you could do that!
Old Apr 16, 2007 | 10:39 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
thats called a manual shift lol.
Old Apr 17, 2007 | 07:46 AM
crazy1291's Avatar
not really- its still an automatic but you have the option of disengaging the forward/reverse gear-
you know how you can't shift into fwd when your RPM is say around 5000rpm......... well with a "clutch" you could, just press it in, shift in fwd, rev it to the moon, and POP- backflip,
So it has all the benefits of a manual clutch but you cannot stall because if your RPM get too low, the CVT tranny will disengage anyway...... see my point?
