Not Charging Correctly
Old Apr 17, 2007 | 12:32 PM
colling's Avatar
Default Not Charging Correctly
On my 2004 A/c 500 I am only getting 12 volts at the battery with the machine running and 11.5 with the lights on. the Stator is putting out the 60ac volts and I am suspecting the regulator. the test for the regulator are all ohm test and I am having huge trouble getting a reading. Any thoughts? The harnees was replaced 1 year ago and I just rebuilt the line from the stator to the regulator due to corrosion. Other than 1200 for a new harness I am willing to try anything!
Thanks in advance,
Chris
Old Apr 17, 2007 | 07:54 PM
buckaroo50's Avatar
Thanks in advance,
Chris
How good condition is your battery (these things only last 2 or 3 years). The lights run directly off the battery. All ATV's are run from a magneto and the 'RPM break point' is around 2000rpm, which means if your engine is running slower than 2000 rpm then it is not charging the battery.
Check the acid level in your battery and put it on a slow charge over night and see if that makes any difference.
Old Apr 18, 2007 | 09:55 AM
colling's Avatar
New battery 3 months ago and trickle charged for 24 hours. battery is at 12 until the machine is on with the lights on. I am still thinking regulator. the book is confusing on testing the ohms. Can you not just test the voltage of the regulator?
Old Apr 18, 2007 | 11:56 AM
upnort's Avatar
Are you getting 60 vac to regulator right at reg? If so then since have new batt would suspect regulator.
ReconBayou
Oct 31, 2022 05:37 PM
speedbuff
13
Nov 11, 2020 10:16 AM
cswiger
Polaris Side by Sides
12
Oct 5, 2015 03:34 PM
2many2ride
Sep 27, 2015 04:35 AM
Elkaholic
Sep 6, 2015 02:44 PM
