How tight are you torquing your front hubs?
Old Apr 18, 2007 | 12:05 PM
NVMYZ28's Avatar
Default How tight are you torquing your front hubs?
So yesterday, I decided to get to the bottom of my 4 wheel drive problem (front hubs randomly decide to go into 4 wheel drive, sometimes only one side would - causing a drag on that side of the quad when moving forward).
So I took both hubs 100% apart last night, and did not find anything unusual. Nothing bent, broken, scratched up etc.
I put everything back together - and followed the torque specs in my service manual for the hub nut on the end of the shaft. However, when I tightend to the exact specs listed - the hubs would stay perma engaged (4 wheeler was up on a stand so all 4 wheels were off the ground for testing).
What I ended up doing was torquing to the initial torque specs the manual suggests, they then suggest backing off 1/2 turn and re-torqee. I backed off 1/2 and left it at that. Hub is secure, and the 4 wheel drive now operates properly.
Is anyone else finding similar results? How tight are you going and maintaining proper 4 wheel drive functionality?
Old Apr 18, 2007 | 12:35 PM
Prariescrammer's Avatar
I do mine by feel...i've replaced a ton of cv joints w/ no problems doing it like this..but when it comes to the 4x4 part i would say normally it's something electrical than mechanical
Old Apr 18, 2007 | 01:33 PM
NVMYZ28's Avatar
Well, I know for sure - at least on my scrambler - that if that nut gets tightend too tight, the hubs would be perma engaged - the magenet was working fine (I tested it both on and off), but if the nut was too tight, the front hubs wouldnt disengage. This seems to be fixed now that I backed the nut off a bit. We'll see how it performs out at the dunes next week.
Bratman2
Aug 6, 2022 01:42 AM
carolinabomb
Jul 26, 2015 08:40 AM
TLC
Jul 25, 2015 02:24 AM
Unzzy66
Jul 11, 2015 10:01 PM
tporath
Jul 11, 2015 12:31 PM
