How tight are you torquing your front hubs?
So yesterday, I decided to get to the bottom of my 4 wheel drive problem (front hubs randomly decide to go into 4 wheel drive, sometimes only one side would - causing a drag on that side of the quad when moving forward).
So I took both hubs 100% apart last night, and did not find anything unusual. Nothing bent, broken, scratched up etc.
I put everything back together - and followed the torque specs in my service manual for the hub nut on the end of the shaft. However, when I tightend to the exact specs listed - the hubs would stay perma engaged (4 wheeler was up on a stand so all 4 wheels were off the ground for testing).
What I ended up doing was torquing to the initial torque specs the manual suggests, they then suggest backing off 1/2 turn and re-torqee. I backed off 1/2 and left it at that. Hub is secure, and the 4 wheel drive now operates properly.
Is anyone else finding similar results? How tight are you going and maintaining proper 4 wheel drive functionality?
Originally posted by: Prariescrammer
I do mine by feel...i've replaced a ton of cv joints w/ no problems doing it like this..but when it comes to the 4x4 part i would say normally it's something electrical than mechanical
2005, atv, front, hub, hubs, replacement, specs, sspecification, tight, torque, torquing, trailblazer, wheels
