250SX cam chain adjustment...how do you?
Old Apr 18, 2007 | 04:56 PM
wrestleu's Avatar
Default 250SX cam chain adjustment...how do you?
Can't figure out the trick to adjusting the cam chain on the SX. I have a manual and it doesn't describe the process in it at all. Any help?
Old Apr 22, 2007 | 07:50 AM
HondaMechanic's Avatar
none
Old Apr 22, 2007 | 05:19 PM
liquiddarkness's Avatar
Make sure your engine is cold and not running. To adjust your cam chain you must remove the adjustment bolt numbered 1 in the pic below. To find this pic open the url. This is just a pic of the adjuster on your bike. You do not need to remove the whole thing, just the middle adjustment bolt. Use a small tipped flathead screwdriver and install into the small hole where the bolt was removed from. Turn it which ever way that starts to feel like a spring is winding up. Wind this adjuster till it its wound as far as it can, then with one quick motion pop out the screwdriver releaseing the tensioner quickly to its needed position. Then replace the bolt you removed and torque to 8 foot pounds.
http://www.putfile.com/pic.php?img=5283245
Old Apr 23, 2007 | 08:00 AM
none
Old Apr 23, 2007 | 05:56 PM
wrestleu's Avatar
Thanks for the info Honda Mechanic. I've never replaced the cam chain on on of these before..but I have done it on a 185S. Is it any more difficult than that?
Old Sep 2, 2020 | 09:36 AM
AjaySummer's Avatar
I know this is quite an old forum, but yes, it is much more difficult. You have to crack open the right crank case cover and remove the centrifugal clutch, manual clutch, oil pump, oil pipe, separator plate, and clutch lifter assembly in order to put new cam chain on the correct gear.
Old Oct 19, 2020 | 09:13 PM
Jte392's Avatar
Ajay, can you show that picture again of the center bolt you were referring to? I have a big red 250es I wanted to try this on if it was the same.
Old Oct 19, 2020 | 10:21 PM
AjaySummer's Avatar
I wasn’t the one that mentioned it, but the person who did was spot on. This is the center bolt you are looking for. The cam chain adjustment is quite easy and only takes a second.
beardouce
Nov 4, 2017 10:28 PM
bvolks
Dec 26, 2015 08:43 PM
bvolks
Aug 27, 2013 10:40 AM
Badshot
Jul 14, 2007 10:01 AM
paulie83
ATC 3-Wheelers
Mar 7, 2005 11:47 AM
