1999 400 sport burning coolant
Old Apr 21, 2007 | 01:41 AM
03scrambler500's Avatar
Default 1999 400 sport burning coolant
I am trying to figure out the problem on a 1999 polaris 400 sport. HPD head, .080 over-bore. It idles great when cold, after first 5minutes burns through half the coolant, at idle there is alittle foam in the coolant, not much. compression is 140 cold. when the engine is cold it will hold the coolant with no leaks. The head and cylinder are flat and it has a new head gasket. What could be the problem???
Thanks Jason
Old Apr 21, 2007 | 02:45 AM
scrammersam's Avatar
if its not a stock gasket then it could be that. i put a cometic in and it blew in like the first hour
Old Apr 21, 2007 | 06:33 AM
stendori's Avatar
Super Quad Patrol
I'm watching you!
if your burning that much it would be pretty easy to tell by smoke and smell.
Old Apr 21, 2007 | 10:25 PM
it is definalty burning the coolant there is lots of whie smoke. The o-rings for the hpd head are what was put in ti and it is sealed. any ideas on what else would cause this thing to leak??
thanks, Jason
Sep 30, 2015 01:37 AM
rockinkgin
Sep 25, 2015 01:52 PM
cboler9
Sep 24, 2015 08:35 PM
95scramblerruben1033
Sep 23, 2015 06:29 PM
