Grease in Venom winch
Old Apr 24, 2007 | 11:18 PM
angler's Avatar
Default new grease in Venom winch
Right now I have my front end on my 05 rubicon tore down, took the bumper off to do some to it and I had to take the winch off to. I was wondering while I had the winch off, I was thinking about putting some new grease inside of it. I have always heard you should put some marine grade grease in there. I just don't know how hard it is. I don't want to open it up and have a bunch of small pieces go everywhere.
Has anybody done this before and how hard is it? This is a Venom 3000 pound winch. How long would it take to complete the job? And is it worth it?
Old Apr 28, 2007 | 11:36 PM
jarmoore's Avatar
Default Grease in Venom winch
Taking it apart is fairly easy. Just keep a note of where all the parts go (there are a ton).
Old May 1, 2007 | 06:24 AM
EigerJoe's Avatar
use a good grease, a cheap grade of grease will melt, turn to oil and drain out, if you use a cheap grease then get a grease that has a high concintration of " Moly", or you can use an expensive synthetic grease such as Mobil 1 or Amsoil, the synthetic grease doesn't melt and they don't absorb water
Old May 1, 2007 | 11:55 PM
angler's Avatar
Where do you put the grease at? I took the motor off and put grease where I could see the gears and turned it a couple times. I did not go any further. Are you supposed to break it down any further than that?
Old May 2, 2007 | 12:59 AM
bobob's Avatar
there are gears on both ends of the spool just grease them and slap her back together
Johnny Mac
Aug 15, 2019 03:13 PM
cboler9
Sep 24, 2015 08:35 PM
bigred20653
Sep 19, 2015 02:11 PM
ylomnstr
Sep 10, 2015 06:45 AM
chewy78
Sep 8, 2015 10:37 AM
