carb cleaner question
Old Apr 26, 2007 | 06:05 PM
TBJAY's Avatar
Default carb cleaner question
this may be a very stupid question but is it ok to run carb cleaner in an atv to keep the carb clean or is it a bad idea? dont laugh i never owned a carbed engine before i prefer fuel injection for my vehicles.
Old Apr 26, 2007 | 08:07 PM
theCATman's Avatar
Go right ahead, I always add 1-2 oz. of cleaner & sta-bil to my 5 gal. jugs in the garage for my quads.
Old Apr 26, 2007 | 11:09 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
when you add carb or fuel cleaner to the tank it does the same thing. you shouldnt have to do it very offen though.
Old Apr 27, 2007 | 01:23 AM
sheepdogMSP8117's Avatar
Couldn't hurt.
Old Apr 27, 2007 | 07:44 AM
vig's Avatar
vig
As long as it is a four stroke, you dont want to put carb cleaner in a two stroke engine, it strips the oil of of the crankcase. I know i have done it on my sea doo.
Old Apr 27, 2007 | 08:16 AM
stendori's Avatar
Super Quad Patrol
I'm watching you!
myself, im a firm beleaver if the carb is dirty, take it off and thoughly clean it rather then taking the easy way out w/ the use of spraying or putting carb cleaner in the gas. but thats just me.
Old Apr 27, 2007 | 09:52 AM
ryker77's Avatar
Some carb "cleaners" are a type of kerosene. They also can if used all the time - dry out rubber parts.
If you want to clean out a carb, intake, head use a product called sea foam its in the carb cleaner section. Use before an oil change. Spray the "sea foam" into the air intake (filter removed) the engine will bogg down and smoke. Let off the spray - it will burn out the cleaner. Repeat a few times. Then one last time spray until the engine dies. Wait a fe minutes then restart -- this will smoke like the worst 2stroke dirt bike you've ever seen. Change oil and your set.
Also great on lawnmowers and cars that have a dirty EGR system. I learned this trick from the V8 Lt1 guys who have a poorly designed EGR in the intake.
Jmuddin284
Jan 19, 2026 07:16 AM
200es
Jul 10, 2015 09:09 AM
tweeder
Jul 5, 2015 01:57 PM
yambam13
Jul 4, 2015 01:49 PM
Mikea1978
Jul 4, 2015 12:37 PM
