Help Emergency (Tire Size)
Old Dec 24, 2000 | 05:13 PM
Jason24's Avatar
I was riding my AC 250 today and managed to get a hole in the side of one of my front tires that is unfixable with a plug, now being that it is the holidays there is nowhere to get it fixed. I recently got a new set of back tires and still have the old set. The front tires are 23-8-12 and the old set of back tires are are 24-9-12, my question is can I put the old set of back tires on the front, will they fit and it so will it make a big difference? I just need to use it for a couple of days until the repair shops open. Any info will be greatly appreciated.
Old Dec 25, 2000 | 12:53 AM
BONER's Avatar
Yea, it will be ok for good if you air up your rear tires about 3 psi more to compensate for tire diameter change.
Old Dec 25, 2000 | 11:37 AM
Ozark's Avatar
If your AC250 is not 4x4 the tire diameter differance shouldn't be a problem. However if it is 4x4 then you will need to air up the rears as Boner said to offset the diameter differance.
Old Dec 25, 2000 | 02:32 PM
Jason24's Avatar
Thanks for the help guys.
Old Dec 25, 2000 | 04:56 PM
sxr6's Avatar
WRONG guys if its a 4wd & your putting a rear ( larger ) on the front ( smaller ) you will need to put less air in it to make it smaller to match. It wont hurt your bike to run it a few days, it's an oppen diff.
Old Dec 26, 2000 | 02:42 AM
BONER's Avatar
No-- cause I said to air u the rear tires, this will make the rear tires larger than the fronts.
Since he was asking if it would hurt his bike I assumed he had a 4wd. But look bellow.
A assumeing will make and an ***(ume) out of (***)U(me) and (assu)me.
***-u-me
Bratman2
Aug 6, 2022 01:42 AM
Hankey Pankey
May 1, 2018 01:33 PM
Hankey Pankey
Aug 17, 2015 05:01 PM
2007 Grizzley 450
Aug 13, 2015 06:33 PM
rcappie4
Jul 18, 2015 07:51 AM
