Blaster...
Old Apr 30, 2007 | 06:38 PM
Slash182169's Avatar
Default blaster problems
well my blaster was running great and then like the next day i went to ride it and it was not even hittin the powerband and when it did it was sputtering, i checked everything i thought my gas may be wet so i put dry gas in and it was the same and i pulled apart the carb and everything was perfect and then i pulled off the head and it was fine one of my friends thinks it maybe electrical but i have no idea. please help
Old Apr 30, 2007 | 11:13 PM
JLsparky7's Avatar
Default Blaster...
You need a e-brake blockoff plate. Take all the e-brake BS off and put the plate on. Your prolly hitting the e-brake rev limiter.
Old May 1, 2007 | 08:37 AM
Default Blaster...
i don't have an e-brake....
Old May 1, 2007 | 08:39 AM
Default Blaster...
another one of my friends said that it could be the spark plug gap or the coil or the stator
Old May 1, 2007 | 05:14 PM
pabst660r's Avatar
Default Blaster...
if you still have the t.o.r.s on your carb now would be a good time to remove it.i know this is a stupid question but did you check your muffler to see if something might be jammed in there blocking exhaust flow?also you might want to check the condition of your reeds for cracks or wear.
Old May 1, 2007 | 08:06 PM
Default Blaster...
yea i checked my silencer im positive thats not it ill check my reeds and get back to you
Old May 1, 2007 | 10:14 PM
Default Blaster...
just checked the reeds they look good thats def no that the problem..
Old May 1, 2007 | 10:21 PM
pabst660r's Avatar
Default Blaster...
i`d start checking electrical connections....if that fails then you might have a bad coil or plug wire.
Old May 1, 2007 | 11:28 PM
holtzer1's Avatar
Default Blaster...
start simple REPLACE the spark plug...dont just check it, or look at it...replace it. you cant "see" a fouled plug. thats what it sounds like. put a new plug in there and try it out. very rarely, like almost never...do you have an electrical issue with a blaster.
Old May 2, 2007 | 04:47 PM
Default Blaster...
i did replace the plug and it stayed the same
2001YamahaShee
Jun 17, 2014 11:52 PM
Leines
Jul 14, 2010 12:49 AM
Badazgt
Jun 25, 2009 10:00 AM
ghettoblaster
Jan 22, 2007 08:28 PM
