Blaster...
well my blaster was running great and then like the next day i went to ride it and it was not even hittin the powerband and when it did it was sputtering, i checked everything i thought my gas may be wet so i put dry gas in and it was the same and i pulled apart the carb and everything was perfect and then i pulled off the head and it was fine one of my friends thinks it maybe electrical but i have no idea. please help
if you still have the t.o.r.s on your carb now would be a good time to remove it.i know this is a stupid question but did you check your muffler to see if something might be jammed in there blocking exhaust flow?also you might want to check the condition of your reeds for cracks or wear.
start simple REPLACE the spark plug...dont just check it, or look at it...replace it. you cant "see" a fouled plug. thats what it sounds like. put a new plug in there and try it out. very rarely, like almost never...do you have an electrical issue with a blaster.
