What kind of clutch is this?
Old May 5, 2007 | 01:05 AM
SilveradoSS's Avatar
Default What kind of clutch is this?
I bought a Coolster 110cc ATV locally and was going through the machine checking all of the fasteners for tightness. I went to check the auto clutch tensioner bolt and found that it free wheels when you loosen the lock nut and turn it with a screwdriver. I tilted the quad over on its side and took off the side cover to get a look at the innards and found the set screw doesnt even connect to the clutch. The bolt/jamb nuts only purpose is to keep the oil from leaking out of the side case??!! Anyone else seen this? Quad runs fine otherwise, so I don't think anything is amiss due to this.
Old May 5, 2007 | 06:41 PM
RacewayATV's Avatar
I have also seen this on some off brand bikes. They do not have a clutch adjustment connection. As from what I have seen this means you will not be able to adjust the clutch.
John.
Kids ATV Raceway ATV
Lou Domenech
Sep 11, 2015 06:35 PM
roy.hawkins3@gmail.com
Sep 11, 2015 02:35 PM
Minimod
Sep 10, 2015 08:03 AM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
cdstang
Aug 31, 2015 07:52 AM
