o4 eton 50cc rev limiter wire cut the green?>
Old May 11, 2007 | 10:23 AM
bryan061975's Avatar
Default o4 eton 50cc rev limiter wire cut the green?>
which wire to this rev limiter gets cut on the 04 model the 05 and up is adjustable. The earlier models i was told u cold cut the wire which one gets cut
Old May 11, 2007 | 10:47 AM
oldyeller's Avatar
If you pull out the cdi box take a look at the side of the cdi..You will see the green wire that comes out and goes right back inside the box..It doesn't come from anywhere else or go anywhere else its just a little loop on the side of the box....It is NOT a part of the harness that plugs into the box...I have pics but can't post them on this site.
Old May 11, 2007 | 10:52 AM
so i cut this loop? its under the front grill this cdi box? Have you noticed power gains? The prob is the rev is what keeps a two strokes powerband up and up a hill it bogs we have tweeked the carb mixing to the hilt and thansk for yr post
Old May 11, 2007 | 11:19 AM
so is it better to cut or buy a hi perf box? whats better?
Old May 11, 2007 | 11:51 AM
oldyeller's Avatar
Just cut the wire and it allows the engine to rev higher...Take off the nose cone and look in to the side of the gas tank on the right hand side as you face the atv.The cdi box is hanging in a rubber holder.You can slide it out and then just snip the wire and tape the ends so they can't touch....Make sure you don't unplug the wiring harness when you are pulling on the cdi box or the engine won't start afterwards.(don't ask me how I know[img]i/expressions/face-icon-small-wink.gif[/img]
Old May 12, 2007 | 08:50 AM
wire cut!!!! runs much bette rthanks guys!!!!!!!!!!!!!!!!!!!!
skinnyr6
Aug 25, 2023 02:18 AM
Ramman1
Aug 11, 2022 01:53 PM
Ramman1
Jun 16, 2016 09:07 PM
house1
Aug 9, 2015 10:49 PM
ScopeZ_
Jul 28, 2015 01:44 AM
