Polaris Phoenix Problems
Old May 15, 2007 | 08:42 AM
wcrook1007's Avatar
Default Polaris Phoenix Problems
My daughters phoenix will only run with the choke on?? What need to be adjusted?
Thanks: Wayne
Old May 15, 2007 | 11:44 PM
sheepdogMSP8117's Avatar
Will it run indefinitely with the choke on? What year, how many hours of use, etc? Just take it out of storage? When was the last time it was run? How did it run then?
My guess is that its an intake issue.
Check everything from the airbox forward to where the intake boot/manifold attaches to the cylinder head. Make sure there's no leak anywhere ahead of the filter. Adjust the idle speed up and see if that helps. If not, check the spark arrestor to make sure it's not clogged. Check/replace the spark plug.
Report back if any of this helps.
Old May 17, 2007 | 05:04 PM
garyhe's Avatar
Check the carb. Make sure ther is no dirt inside. Had the samething happin to my 330. I pulled the carb, cleaned it , found a very smal rock. I checked the intake and found that the factory had put the hose clamp on wrong and tore the hose.
Replaced the intake hose. I haven't had a problem sense. That was a year ago.
Old Jul 24, 2007 | 01:00 AM
sarge2507's Avatar
I have a 2006 Polaris Phoenix that my daughter was driving today. She turned it off and it would not start. I checked the battery dead. So I jumped it and drove it. I stopped and it sputtered and died. Jumped it again. Drove it and heard a loud pop.
Now it wont start or anything. The battery is dead as a doornail. Hooked a new battery and nothing. The fuse also was blown and when replaced blew again.
any ideas would help I bought it used back in october so I dont know if the dealer will fix or not??? I think the ECM maybe out but how can i check it??
Old Jul 24, 2007 | 09:47 AM
wcrook1007's Avatar
There was a recall on the Phoenix on the ECM being bad (over heating) but not real sure you can call a dealer and they should tell you if there is a service bulletin or not. Try and adjust the ETC cable on the gas it might be out of adjustment. Make sure the battery cables are not grounding out on the frame? Just guessing??
Wayne
Old Jul 24, 2007 | 02:54 PM
sarge2507's Avatar
the battery is DOA now and the neutral light will not come on now. It turned over for a minute but that it. I think its a electrical issue. Ill take it to the polaris people if there is a recall. Had to do the same with my 05 trail boss same issue. But with it the cooling fan would just come on by itself without the key in and it would show hot when it had not been rode.
green giant
Jul 13, 2017 12:07 PM
bowhunter38
Jun 14, 2015 04:38 PM
TJM
Jun 11, 2015 01:28 PM
Jun 10, 2015 11:20 PM
