fluids
Old May 16, 2007 | 10:14 PM
trailblazermudrunner's Avatar
Default fluids
hey guys i need to know the fluid level on mi kawi 360 for the front diff and the rear end
Old May 17, 2007 | 08:05 AM
Default fluids
any one
Old May 17, 2007 | 08:55 AM
aduke's Avatar
Default fluids
2-20 PERIODIC MAINTENANCE
Periodic Maintenance Procedures
Rear Final Gear Case Oil Change
. Warm up the oil by running the vehicle so that the oil will pick up any
sediment and drain easily. Then stop the vehicle.
. Park the vehicle so that it is level, both side-to-side and front-to-rear.
. Place an oil pan beneath the rear final gear case and remove the
drain plug [A].
When draining or filling the final gear case, be careful that no
oil gets on the tire or rim because oil will deteriorate the tire.
Clean off any oil that inadvertently gets on them with a highflash
point solvent.
. After the oil has completely drained out, install the drain plug with a
new aluminum gasket.
Torque - Oil Drain Plug: 20 Nm (2.0 kgm, 14 ftlb)
<span class="FTHighlightFont">. Fill the final gear case up to the bottom of filler opening with the oil
specified below.</span ft>Rear Final Gear Case Oil
Type: MOBIL Fluid 424 or Kawa Chem Gear & Wet Brake Oil
(CITGO TRANSGARD TRACTOR HYDRAULIC FLUID)
Capacity: 900 mL (0.95 US qt)
. Be sure the O-ring is in place.
Torque - Oil Filler Cap [b]: 29 Nm (3.0 kgm, 22 ftlb)
Old May 17, 2007 | 08:58 AM
aduke's Avatar
Default fluids
Front Final Gear Case Oil Change
. Remove the front side cover (see Frame chapter).
. Place an oil pan beneath the front final gear case and remove the
drain plug [A].
oil gets on the tire or rim. Clean off any oil that inadvertently
gets on them with a high-flash point solvent.
new aluminum gasket, and tighten it.
Torque - Oil Drain Plug: 24 Nm (2.4 kgm, 17 ftlb)
.<span class="FTHighlightFont"> Fill the gear case up to the bottom of filler opening with the oil
specified below.</span ft>Front Final Gear Case Oil
Type: API SF or SG
API SH or SJ with JASO MA
Viscosity: SAE 10W-40
Capacity: 430 mL (0.45 US qt)
NOTE
Depending on the atmospheric temperature of your riding area, the
engine oil viscosity should be changed according to the chart.
. Be sure the O-ring is in place, and tighten the filler cap.
Torque - Oil Filler Cap : 29 Nm (3.0 kgm, 22 ftlb)
Old May 18, 2007 | 12:21 AM
Default fluids
can i use 80-90 gear oil???????in the front
Old May 18, 2007 | 12:40 AM
Strjock81's Avatar
Default fluids
DO NOT use anything but a 10w-40 JASO MA oil in these front ends!
I wanted to do the same thing as you, ie., put in a good gear oil. However, the clutch system that regulates your locking differential requires friction to work properly. Using a highly friction modified automobile oil (basically an non-motorcycle specific oil you might pick up somewhere would fall into this category) can and will cause degradation of the ability of those clutch packs to grab like they should. So will gear oil.
I keep seeing 'tards on boards complaining that their lever is tight and adjusted properly but they can't get their front differential to lock. Came to find out in every case they either put a "slick" auto type of oil in them, or a GL-5 gear oil. Just stick with JASO MA 10w-40, maybe even 20w-50 if you ride in lots of hot temps and long durations. But I would definitely NOT use either gear oil or automotive 10w-40.
Old May 18, 2007 | 08:59 PM
Default fluids
okie thanks so much for the info where would i find that JASO MA 10W-40?????
Old May 20, 2007 | 01:10 PM
newbruterider's Avatar
Default fluids
Auto Zone . I run Valvoline 10w-40 4-stroke motorcycle oil. It is JASO MA , API SG compliant.. And it's only about 3.30/quart. You can use this in the engine and the front end.
Old May 21, 2007 | 09:58 PM
Default fluids
okie got to ask this i have a quart of amz oil 0 40w thats a syn. that i dont need will that work im running the kawi stuff the motor but i picked this quart up in a box that mi brother gave me after he cleand out his grage and i have a bunch of other cleaning fluids but i didnt dump that amsoil?????
Old May 23, 2007 | 10:08 PM
Default fluids
any one
MaasaiMomma
Mar 25, 2021 11:24 AM
hueby
Nov 6, 2015 11:34 AM
twon1235
Utility ATVs
Sep 7, 2015 04:38 AM
Technical and How-To Articles
Aug 21, 2015 09:31 AM
rcappie4
Jul 10, 2015 04:54 PM
