UGH!! Can't find the squeak on Outty 800XT
Old May 21, 2007 | 03:49 AM
Gadget756's Avatar
Default UGH!! Can't find the squeak on Outty 800XT
Okay, okay, lubed all fittings, checked the rear shock mounts, wheels are tight, squirted springs with CLP, can't seem to locate a loud squeak in the rear suspension when the bike rocks side to side (like getting on and off).
This is the second squeak of this kind heard (my buddy's 800 does it too) so I'm not alone here and not imagining this. Kinda sounds aluminum.
The noise is only made (from the rear suspension) when the bike rocks side to side. No vertical travel noise- ever. I looked everywhere for a fitting I missed, but no idea. Also had a buddy look (who is a tech at the dealer) and he wasn't sure (for free that is- lol).
HELP- I'm going nuts.[img]i/expressions/face-icon-small-confused.gif[/img]
Old May 21, 2007 | 11:13 PM
kawiyowee's Avatar
I'm gettin' under mine tomorrow, will try to find something. You're right, that's usually metal on metal, usually a loose bolt. Did you ck your engine mounts? Need to ck them every so often anyway.
Old May 22, 2007 | 02:24 AM
kawiyowee's Avatar
Found a thread similar to yours, the culprit was the tti or torque arms.
Old Jun 4, 2007 | 11:17 PM
MOTOMAX4's Avatar
My 2006 Outti 800 had exact same issue last fall. Dealer found that one of the nuts on the rear suspension torsion bar had worked loose. They also found moisture in the torsion bar housing although the bearings weren't affected. They cleaned everything up and re-assembled and the noise completely dissapeared.
Problem now is that I noticed last weekend the sound is coming back. Same symptons as before. Squeak is only heard when rocking side to side or going over un-even terrain where the wheels have to work independatly. Looks like its going back to the dealer.
Zehno
Sport Quads
Jan 2, 2016 01:31 PM
Randy Marsh
3) General Discussions..
21
Nov 10, 2015 01:45 PM
BigT137
Aug 19, 2015 12:09 AM
Cantbuytime
Aug 17, 2015 06:33 PM
papahouse
Jul 28, 2015 12:42 PM
