engine brake
Old May 22, 2007 | 10:31 PM
kvfrider's Avatar
Default engine brake
I know the engine brake cycles when the ignition is turned off, but on my 04 prarie it has started to cycle for a very long time after shutdown. From what I have read on this forum it sounds like it may have something to do with my 4wd/2wd lights flashing. Am I correct in assuming this? Any ideas on a repair?
kvfrider
Old May 23, 2007 | 01:07 AM
alwaysride's Avatar
well, thats what mine did. Eventually it just went out. I decided that it was dumb to spend 200 to get a new one so i just put a peice of electical tape over the light, and took the actuator fork out so that the actuator isnt connected to the belt anymore and was done with it. Like it allot better now and still have all the engine braking just have to tap the throttle every little bit. Its a popular mod to do. So simple.
Old May 23, 2007 | 12:39 PM
asnowmobiler's Avatar
If you remove the fork for the engine brake,you should remove the bearing that's on the clutch face, a few guys had them fall out and cause some damage.
Old May 24, 2007 | 04:44 PM
aduke's Avatar
I haven't taken out the actuator fork yet but I did use the black tap for the leds flashing
Old May 25, 2007 | 01:35 AM
imstuck's Avatar
dg makes a module to remove the flash of lights and the kebc brake its 80.00
Johnclay
Utility ATVs
Jul 19, 2015 10:00 AM
KimSJoh
14
Jul 18, 2015 07:20 PM
clsharky
Jul 13, 2015 02:07 PM
timster911
Jul 13, 2015 01:57 PM
MNatv89
Jul 7, 2015 11:36 AM
