Tierods
Old May 24, 2007 | 09:11 PM
Polaris-Nut's Avatar
Default Tierods
Hello All
Can someone help me I have a question I have a 1999 Polaris Magnum 500 that needs tierod ends my question is that. I see that Polaris has gone to a new outer rod end that looks the same as the inner rod ends that look the same on my 1999 they look like the heim joint with a rubber boot and the bolt that goes through not the pivit bolt on the old ones so i need to know if i can use the same rodends that are used on the inner tierods for the outer tierod ends. Thank You Polaris-Nut
Old May 24, 2007 | 09:47 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
Default Tierods
i know the trailblazers changed then as well. they make replacement ones as you describe but not sure w/out looking at part numbers.
TJw6981
Oct 28, 2003 09:56 AM
660bigdaddy
Jan 20, 2003 03:32 AM
warrior007
Jul 30, 2002 10:19 AM
jviper85
Jan 23, 2001 06:11 PM
