idle problem
Old Jun 8, 2007 | 11:11 PM
Matt1980's Avatar
Default idle problem
My 1999 300ex's idle is really high. What do i do
Old Jun 9, 2007 | 02:06 AM
hondarules666's Avatar
well if you have a manual it should tell you where the idle screw is. it should be a gold screw on the side of your carberator turn the screw out to turn it down i belive but before you do this let it warm up to get an accurate idle.
Old Jun 9, 2007 | 06:09 PM
TommyA300's Avatar
<div class="FTQUOTE"><begin quote>Originally posted by: hondarules666
well if you have a manual it should tell you where the idle screw is. it should be a gold screw on the side of your carberator turn the screw out to turn it down i belive but before you do this let it warm up to get an accurate idle.</end quote></div>
Yepper the best bet is to get a manual.
I had a friend that always needed help and not to many had answered to his calls.
Natch I could not help him since he had an odd way about him.
Ever since he got a manual and learned to enjoy the reading!
I have not heard from him very much after.
He was always out riding every chance he got.
Well Good Luck to all
Old Jun 12, 2007 | 05:41 PM
Matt1980's Avatar
I have the Cymer manual and I cant find anything about an idle screw
Old Jun 18, 2007 | 06:35 PM
it should be a gold screw on the side of the carb if the idle is to low then turn the screw in to the carb
Old Jun 19, 2007 | 03:04 PM
HondaRacer01's Avatar
Yeah, your idle screw is too far in and you may also, have a clog somwhere in your hoses for the gas. Check our your filters and make sure there isnt any clogs and if there is replace them. If you take apart the carb. carefully there is a gold screw turn it out a little bit i can get you a copy if you need one of the manual.
Old Jun 19, 2007 | 09:07 PM
Matt1980's Avatar
I got the idle down and need to know how to tell if it is to low
Old Jun 19, 2007 | 10:20 PM
You can tell when it starts and it stalls if it doesnt but it idles low. then your pretty good
Old Jun 20, 2007 | 01:53 PM
if its to low it wont run or it will only run for a few seconds but when you do get your idle right it will be able to run by it self but you only have to give it gas like once or twice then it warms it self up. i think the rpms specs for a good idle are between 400-1000.
KimSJoh
14
Jul 18, 2015 07:20 PM
ranvette
Jul 12, 2015 06:34 AM
Robbbb55
CAN-AM (BRP) Ask an Expert!
Jul 8, 2015 02:16 PM
Robbbb55
Jul 8, 2015 02:11 PM
MNatv89
Jul 7, 2015 11:36 AM
